18 Apr 2024 03:52 PM
Afternoon
I have a SKY Q box around 3 years old and have just upgraded to a new Phillips 908 (MLA Screen).
I have 3 questions
Why is the HDR picture so grainey?
Have Sky got a new Sky Q Box that is better than mine?
Do they come out for free to re route my dish cable if requested?
The TV i have is amazing but the picture quality from the box is not
18 Apr 2024 04:23 PM
@Leepeugeot wrote:Have Sky got a new Sky Q Box that is better than mine?
Without knowing the model number we can't say... https://www.sky.com/help/articles/sky-software-updates
But if you have a HDR capable box then it's the 'latest'.
They are likely to charge for that.
18 Apr 2024 04:32 PM
@Leepeugeot wrote:Afternoon
I have 3 questions
Your TV is using technology which is much newer than Sky Q.
Sky Q's UHD HDR uses the HLG format which isn't the best. Sky content is usually more compressed than a lot of streamed content for example, and can therefore look a bit posterised/grainy.
Don't use any of the apps on the Q box - you will get vastly superior UHD HDR quality from the TV's own apps which will give you Dolby Vision and HDR10+ where available. Sky Q's apps can output HDR10 at best.
18 Apr 2024 06:22 PM
Would it be better if I had Sky Stream? Do you think they will bring out a new more uptodate box?
18 Apr 2024 09:57 PM
I have used both Sky Q at my house and Sky stream at my moms house, and I can say that HDR looks so much crisper on stream than on Q,
19 Apr 2024 07:57 AM
@Leepeugeot wrote:Would it be better if I had Sky Stream? Do you think they will bring out a new more uptodate box?
Sky Stream does have newer and better video processing than Sky Q but has its own issues and limitations, particularly if you like the ability to record and fast forward/rewind easily.
There will not be an updated Sky Q box in the future. It is obsolete tech, designed & released under the old Murdoch administration at Sky.
19 Apr 2024 05:16 PM
You also have to take into account that Sky most likely will not be renewing their satellite carriage agreement with SES in 2028.
