Discussion topic: SKY Q Box not connecting to TV
Message posted on 14 Apr 2021 10:44 AM
I have switched on my Sky Q box and TV but the box does not connect to the TV. The HDMI cable is firmly plugged into both Box and TV. I have put new batteries into the Sky Q remote.. Now the remote will not the Box off. Any ideas? Thank you
Message posted on 14 Apr 2021 10:45 AM
Hi @JoeA125
First thing to try is a Qbox reboot.
Hi @JoeA125
Message posted on 14 Apr 2021 11:13 AM
Re: SKY Q Box not connecting to TV
Thanks Oldfella worked a treat.
Message posted on 23 Oct 2021 02:01 PM
This doesn't work. I purchased a 4k hdmi cable but for some silly reason, it only works with the sky hdmi supplied. The one with the pink connector on the end why is this?? Reset the sky box but still doesn't do anything. I am needing a longer cable which is why I purchased a new one. So frustrating
Message posted on 23 Oct 2021 03:04 PM - last edited: 23 Oct 2021 03:06 PM
@wazzalfc wrote:This doesn't work. I purchased a 4k hdmi cable but for some silly reason, it only works with the sky hdmi supplied. The one with the pink connector on the end why is this?? Reset the sky box but still doesn't do anything. I am needing a longer cable which is why I purchased a new one. So frustrating
@wazzalfc have you got the spec of the new longer HDMI cable you bought and what is the length ?
It should be, at least, 'high-speed' , 18 Gbps, HDMI 2.0 and below 3m for 4k use
Sky Q 1TB UHD
LG TV
Sky Mobile
