Discussion topic: SKY Q BIX ISSUES
This message was authored by: Mob33n
SKY Q BIX ISSUES
Hello,
I hope you can help. Our TV is showing a strip on colour on the screen at the bottom.  I originally thought it was an issues with the TV but have been advised that's its the Sky Q Box.
Re: SKY Q BIX ISSUES
@Mob33n
Who's advised you it's the Sky box? Perhaps you could submit an image of the screen.
Avatar for Mob33n
Samsung who we purchased the TV from
@Mob33n
I've just spotted you haven't attained level 1 yet so can't send images. What have you tried?
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if necessary-
~ press the 🏠 button
Avatar for Mob33n
I have tried all the above that you advised but it has not worked.  Also how do I qualify to level so I am able to send picture evidence.
This message was authored by: Doc5907
Type one or two more posts and/or like other replies on this thread
Sky Q 1TB UHD
LG TV
Sky Mobile
This message was authored by: bemak187
@Mob33nDo other things work on the TV like menus, built in apps, other HDMI sources?  If not then its very likely the TV.
Avatar for Mob33n
Yes other features and apps work.  I will also contact Samsung as I think the issue is with the TV too. Thanks
Avatar for Mob33n
All the other features work. I think the issue is with the TV too. Thanks.
You should be able to post a photo of the issue now.
Sky Q 1TB UHD
LG TV
Sky Mobile
