Discussion topic: Roxi sign out button not there. How can i sign out?
This message was authored by: Suzyq20
Want to change user but no sign out button available as per instructions.
Any suggestions?
Re: Roxi sign out button not there. How can i sign out?
Any suggestions?
Hi @Suzyq20
Don't use Roxi  here but the safest way to Sign out of Apps that don't have a Sign out button is to repeatedly press the Q remote Dismiss button (left of Home button) until you Exit the App (unless of course there is not an Exit button instead of a Sign out button)
You can just press the Home button on the Remote provided you don't experience later issue with the App.
Above assumes that you can select a different user when reopening the App.
So how can I sign out of roxi so I can sign back in with a different email thanks @Chloe-W22
