1
This discussion topic has been answered Discussion topic: Rewind TV 182 Blank EPG on TV Guide
This message was authored by: Richjc
I am trying to set my Sky Q to record a programme on this channel but the EPG guide for this channel has alot of Blanks in the time slots.
Is this a known issue or is there something i can do in order to record a programme
Thanks for any help
Re: Rewind TV 182 Blank EPG on TV Guide
@Richjc
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Give it 5-10 minutes before checking the epg again.
@Richjc
