Discussion topic: Returned from being away, no satellite signal on our Sky Q and tried to reset and now remote wont co
This message was authored by: Donnamiller
Returned from being away, sky q has no satellite signal, followed instructions to rest the box but now handset is unpaired and won't reconnect after pressing 7 and 9 and 1 and 3 and now sky is just a blank blue screen.
Still no satellite signal 😒
Re: Returned from being away, no satellite signal on our Sky Q and tried to reset and now remote won
Dish probably moved (or cables damaged?) while you were away?
Remote pairing not working is very unusual. Do you have a 2nd remote you can try?
This message was authored by: Manjinder1
My remote control is not working
@Manjinder1
Not a lot to go on. Check the basics, ie; fresh batteries, re-pairing etc. If your Sky Q remote is definitely broken/faulty, if you follow this link it should allow you to do some more troubleshooting and then it’ll send you to a form to request a replacement (apparently this is not available to customers in the ROI).
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
It may be quicker to purchase a new remote from a retailer or larger supermarket. If you do that as well you’ll have a spare.
