3
This discussion topic has been answered Discussion topic: Return sky products how to reset to factory settings
This message was authored by: MitsyToots
Return sky Q products how to reset to factory settings as I am leaving sky and concerned about leaving personal data on the boxes
This message was authored by: MightyQuinn Answer
Re: Return sky products how to reset to factory settings
Hi @MitsyToots   No need to worry as Sky wipe the boxes, but you can reset the box in the hidden menu.
  1. Press the ‘Home’ button on your remote control.
  2. Scroll down to ‘Settings’ and do not press select.
  3. Press ‘001’.
  4. Press Select.
  3. Press ‘001’.
  4. Press Select.
There is no personal data on your Q box @MitsyToots .
Only your recording history.
However you can carry out a factory reset in the Q box hidden menu.
Carry out the Factory reset.
This message was authored by: Ajaxajax
When you say there is no personal data, I presume you are overlooking all the streaming passwords for services like netflix, prime, disney, etc?
