Discussion topic: Restart q box every time I put it on
Message posted on 19 Jun 2025 04:03 PM
I have to restart my q box every time input tv on. It's been going on for weeks so nothing to do with weather
Message posted on 19 Jun 2025 04:16 PM
Re: Restart q box every time I put it on
Hi @rainiesm
Assume your Q box is in Standy and not completely switched off at the mains.
Also note that switching on your Television set will not switch on the Q box.
To switch the Q box you need a normal short press on the Q remote. Provided HDMI control is switched on in the Q box settings and also in the Television settings, the short press should switch on both devices.
