11
This discussion topic has been answered Discussion topic: Reset my pin because I don’t know it
This message was authored by: Babs+carpenter
I need to change my pin because I don't know it . on screen it says to put old pin in but I can't I don't know it
Re: Reset my pin because I don’t know it
@Babs+carpenter
  1. Press Home on your Sky Q remote.
  2. Select My Sky then Reset PIN.
  3. Enter the last 4 digits of the bank account used to pay your Sky bill.
  4. Follow the on-screen instructions to set a new PIN. You'll see an on-screen confirmation message saying "Your PIN has been successfully changed".
https://www.sky.com/help/articles/your-pin-sky-q-unblock
@Babs+carpenter
@Babs+carpenter
If you've never changed your TV PIN, it'll be the last four digits of your viewing card number.
Find it by going into Settings then System Info or System Details.
This message was authored by: Steveday
I do not know what my viewing card is
This message was authored by: Paulconnolly1
I need to set up my pin number
The default is the last 4 digits of your viewing card
(you can view this  Home - Settings -  System Info)
If you need to reset it please see  @TimmyBGood 's post  #2
This message was authored by: Kapory-90
I can't remember my pin
Read the posts above
This message was authored by: Edgar3
@Edgar3
Have you read post 2 in this thread?
This message was authored by: Peterwilkinson
To reset my pin
@Peterwilkinson wrote:
To reset my pin
...if only the answer was on this very thread.  (See post #2)
