This discussion topic has been answered Discussion topic: Reset my pin because I don’t know it
Message posted on 13 Nov 2023 02:31 PM
I need to change my pin because I don't know it . on screen it says to put old pin in but I can't I don't know it
Message posted on 13 Nov 2023 05:04 PM
- Press Home on your Sky Q remote.
- Select My Sky then Reset PIN.
- Enter the last 4 digits of the bank account used to pay your Sky bill.
- Follow the on-screen instructions to set a new PIN. You'll see an on-screen confirmation message saying "Your PIN has been successfully changed".
https://www.sky.com/help/articles/your-pin-sky-q-unblock
Message posted on 13 Nov 2023 05:05 PM - last edited: 13 Nov 2023 05:05 PM
Re: Reset my pin because I don’t know it
If you've never changed your TV PIN, it'll be the last four digits of your viewing card number.
Find it by going into Settings then System Info or System Details.
Message posted on 02 Aug 2024 08:55 PM
I do not know what my viewing card is
Message posted on 03 Jan 2025 08:54 PM
I need to set up my pin number
Message posted on 03 Jan 2025 09:10 PM
The default is the last 4 digits of your viewing card
(you can view this Home - Settings - System Info)
If you need to reset it please see @TimmyBGood 's post #2
Message posted on 05 Feb 2025 04:33 AM
I can't remember my pin
Message posted on 05 Feb 2025 07:55 AM
@Kapory-90 wrote:I can't remember my pin
Read the posts above
Message posted on 04 Apr 2025 05:44 PM
Message posted on 04 Apr 2025 05:46 PM
Have you read post 2 in this thread?
Message posted on 19 Apr 2025 05:18 PM
To reset my pin
Message posted on 19 Apr 2025 05:23 PM
@Peterwilkinson wrote:To reset my pin
...if only the answer was on this very thread. (See post #2)
