Discussion topic: Reset hard drive; pressing 0,0,1 has no effect
This message was authored by: clayts5765
Advise says press 0,0,1 (on hand set?) to reset but this has no effect - anybody able to help?
Re: Reset hard drive; pressing 0,0,1 has no effect
Hi @clayts5765
Resets are in the hidden menu
If the hard drive has failed then reseting it won't fix it.  (Or may mask the issue for a while)
