This discussion topic has been answered Discussion topic: Replaced my Sky Q remote low battery same message with new remote?
Message posted on ā03 Apr 2024 08:44 PM
Had to replace Sky Q remote, thought old remote was draining batteries (replaced batteries numerous times). After one day the new remote is doing the same thing, low batterry messsge𤷠Brand New genuine Sky Q remote with brand new Duracell batteries. Any ideas?
fyi - Panasonic TV and I've paired remote with TV
Message posted on ā03 Apr 2024 09:06 PM
Hi @Duffys2
Try removing the batteries and then press each button on the remote.
Replace the batteries and then completly reset the remote as follows
Press and hold 7 & 9 together on the remote until itās led flashes four times.
Hi @Duffys2
Message posted on ā03 Apr 2024 09:13 PM
Re: Replaced my Sky Q remote low battery same message with new remote?
Thanks for speedy response oldfellaš
Ill give it a go as soon as my wife finishes watching MAFS ā¹ļø
ps feels wrong to call you oldfellaš¤
Message posted on ā03 Apr 2024 09:18 PM
Message posted on ā03 Apr 2024 09:29 PM
Hi OldFella,
you diamond that workedš„³
Thank Youš
Message posted on ā03 Apr 2024 09:32 PM
Message posted on ā03 Apr 2024 09:39 PM
