6
This discussion topic has been answered Discussion topic: Replaced my Sky Q remote low battery same message with new remote?
This message was authored by: Duffys2
Had to replace Sky Q remote, thought old remote was draining batteries (replaced batteries numerous times). After one day the new remote is doing the same thing, low batterry messsge🤷 Brand New genuine Sky Q remote with brand new Duracell batteries. Any ideas?
fyi - Panasonic TV and I've paired remote with TV
Re: Replaced my Sky Q remote low battery same message with new remote?
Hi @Duffys2
Try removing the batteries and then press each button on the remote.
Replace the batteries and then  completly reset the remote as follows
Hi @Duffys2
Avatar for Duffys2
Thanks for speedy response oldfellašŸ˜‰
Ill give it a go as soon as my wife finishes watching MAFS ā˜¹ļø
ps feels wrong to call you oldfella🤭
Hi @Duffys2
Afraid that's what I am.
PS
You can can 'tag' someone in your post by tying the @ symbol
Avatar for Duffys2
Hi OldFella,
you diamond that worked🄳
Thank You😘
Avatar for Duffys2
Hi @oldfella
Thank You😘
@Duffys2 wrote:
Hi @oldfella
Thank You😘
There you Go @Duffys2
Answered - Go to Answer
