Discussion topic: Removing items from my package
This message was authored by: Debr2
  • I want to find out what I can remove from my package to make it cheaper
Re: Removing items from my package
@Debr2
To remove a part of your TV package you need to contact Sky giving the standard 31 days notice. If you have 'in contract' discounts you may not be able to remove them. Also make sure cancellation of a certain add-on doesn’t cancel another part of a discount.
You may be able to remove it via this link which includes a message option (usually available between 9am & 7.30pm) or by calling in using the number that will appear.
https://www.sky.com/help/articles/change-your-package-2-t2#downgrade
This message was authored by: Simples2810
Remove subscription
@Simples2810 wrote:
Remove subscription
Post #2 seems to answer your question...
