Discussion topic: Remove sky pin on phone app
Message posted on 18 Aug 2025 09:14 AM
One of my numbers is not working on my controller and I can't put in my pin to watch something how do I remove the pin from my app on my phone
Message posted on 18 Aug 2025 09:54 AM
Re: Remove sky pin on phone app
The pin can not be removed as it is an OFCOM requirement that says broadcasters like Sky have to have it place for what age restricted contact before the evening watershed.
Message posted on 18 Aug 2025 09:56 AM
@Tolsey wrote:One of my numbers is not working on my controller and I can't put in my pin to watch something how do I remove the pin from my app on my phone
There's a virtual controller on the Sky app - that might give you a workaround whilst you get a new remote: https://www.sky.com/help/forms/replaceremote
Message posted on 18 Aug 2025 10:04 AM
Where can I find that and does it work with sky glass or just sky Q
Message posted on 18 Aug 2025 10:18 AM
@Tolsey wrote:Where can I find that and does it work with sky glass or just sky Q
SkyGo app. Definitely works on Q, not sure about Glass/Stream.
