Discussion topic: Remote wasnt responding so I pressed 7 and 9, then 1and3, it's not responding
Message posted on 27 Mar 2024 09:02 AM
Hi, my remote wasn't working to full capacity so I pressed 7+9 then 1+3, the remote stopped responding altogether, anyone have any suggestions? I don't want to be without a tv for the whole Easter weekend and school holidays 🙃 thanks
Message posted on 27 Mar 2024 09:06 AM
							Re: Remote wasnt responding so I pressed 7 and 9, then 1and3, it's not responding
As a workaround you can use the remote control icon in the top right hand corner of the Sky Go app
Message posted on 27 Mar 2024 09:12 AM
Good idea, however I just checked and I don't seem to have the remote control icon on my sky go app 😑, maybe I can screen share if need be
Message posted on 27 Mar 2024 09:52 AM
Message posted on 27 Mar 2024 09:55 AM
Hi @Deankm
Did the remote led flash 4 times when you pressed and held 7 & 9 together?
Try rebooting your Q box again.
When the box is back up and running
Try completly resetting your Bluetooth remote again.
Message posted on 27 Mar 2024 09:56 AM
hi cannot connect my tv to internet
Message posted on 27 Mar 2024 10:04 AM
Ah that must be the problem, I have Android
Message posted on 27 Mar 2024 10:16 AM
Hi Iv just tried your suggestion, the standby on the remote doesn't work so I pressed the box then unplugged and fallowed your instructions, still not responding, the led flashed on the remote when I press 7+9, and 1+3 but it still doesn't seem to pair the box
Message posted on 30 Mar 2024 10:07 AM
I am having same issue , switching of , resetting using 001 , trying 7 / 9 but nothing , however remote from another box in home is working but does not work volume. .. any ideas , is it a new remote I need ? Oh and new batteries were used
Message posted on 30 Mar 2024 10:29 AM
Follow the steps here to setup your remote control : https://www.sky.com/help/home/sky-tv/sky-tv-q/setting-up-sky-q/setting-up-sky-q-remote/articles/touc...
Message posted on 30 Mar 2024 10:38 AM
Hi @Deankm
The Q box needs to be on with green led when you reset the Remote.
Switch it on using the Standby button on the box (Amber led)
