4
This discussion topic has been answered Discussion topic: Remote control set up hangs on step 3. Says "please wait" but never moves on from there
This message was authored by: Phil641
Remote control set up hangs on step 3. Says "please wait" but never moves on from there. I am in the settings section trying to pair sky remote to TV volume etc
Avatar for Phil641
This message was authored by: Phil641 Answer
Re: Remote control set up hangs on step 3. Says "please wait" but never moves on from ther
Sorry for delay. Managed to try this today and pressing the button for 3 seconds does turn the TV off, I hadn't pressed for long enough before.
Many thanks for the advice and resolution.
Hi @Phil641
First reboot your Q box.
Have you tried rebooting your Q box?
Then try pairing again
Avatar for Phil641
Very helpful thanks.  Volume controls now work and I can switch the sky box on with it (I could do this step before anyway) .  Unfortunately I can't switch the TV off with the remote though.  Please advise.
Hi @Phil641
Are you pressing the standby button on the Remote for approx 3 seconds to turn the TV On or Off?
Avatar for Phil641
