Discussion topic: Remote control kept falling apart so I super glue it together now I can't turn the TV Hitachi V21C0
This message was authored by: Rustie
Can you help please 🙏 I can't find any buttons on the back or sides of the TV
Re: Remote control kept falling apart so I super glue it together now I can't turn the TV Hitachi V
What does this mean?  And how does it relate to super gluing the remote?
You can buy a new remote or ask Sky for a replacement.
@Rustie
If you mean the Sky Q remote and not your TV remote, if you follow this link it should eventually send you to a form to request a replacement (there is the possibility this is not available to customers in the ROI).
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
It may be quicker to purchase a new remote from a retailer / larger supermarket. If you do that as well as the above you’ll have a spare.
In the meantime if you have an Apple device with Sky Go you can possibly set up a virtual remote to control your Sky Q box. See this link which may help
https://helpforum.sky.com/t5/Sky-TV/Virtual-Sky-Q-Remote-Now-Available-on-Sky-Go/ba-p/4363637?
