Discussion topic: Red button not working and recordings which are UHD WILL NOT PLAY ON MY TV
This message was authored by: YPL
Received a replacement mini box from Sky a couple of weeks ago. My recordings in UHD will not play on the tv and also the red button will not work. If I press it nothing happens. The other TV's work fine.
The TV in question is a Panasonic.
Re: Red button not working and recordings which are UHD WILL NOT PLAY ON MY TV
@YPL
UHD recording/viewing is not possible on a mini box.
Avatar for YPL
How do I record my Sky F1 channel which showing as UHD but this will not play on he upstairs TV. How do I record F1 in SD?
hi @YPL
You can record F1 in HD on channel 857
Hi @YPL   You record in HD (channel 857). I always record in both UHD and HD so I can watch on the Mini box if needed. I also have both UHD & HD in my favourites.
Avatar for YPL
Hi,
Thank you but channel 857 is not available to me for some reason.
@YPL wrote:
Hi,
hi @YPL
In what way not available - not listed ? or showing a problem ?
If it is not listed just look for SKY F1 HD  in the listings
@nigea99 wrote:
@YPL wrote:
Hi,
hi @YPL
Just realised if you are looking on the mini box tyhe F1 HD channel will show as 406 on it so set from the mini box or look for 857 on the main box
