Discussion topic: Recordings not showing on mini box Sky Q
Message posted on 20 Jan 2025 09:42 AM
Recordings not showing on SkyQ mini box
Message posted on 20 Jan 2025 11:06 AM
Re: Recordings not showing on mini box Sky Q
@Sevetiger
Try a reboot of your router first, then the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
