Discussion topic: Recordings no longer loading apps icons not showing
Message posted on 08 Jul 2023 08:04 PM
While watching a recording tonight, it kept on sticking and the 'technical fault with this programme' message came up. Rebooted q box, to no avail. We then also did the reset via the hidden menu and also rebooted our router. Now all recordings have disappeared and the screen states 'please wait' and whirrs around but doesn't load. When going to apps, only the Netflix and a few other icons are showing, although the actual apps behind the blue squares seem to be loading. We have done the app refresh via hidden menu. We are at a loss now as to what else to do. All connections are showing as ok and no issues with any other hardware in the property
Message posted on 08 Jul 2023 08:08 PM
Re: Recordings no longer loading apps icons not showing
Hi @polar68
Which reset did you do in the hidden menu?
Also bear in mind a refresh Apps can take up to 24 hrs.
Message posted on 08 Jul 2023 08:09 PM
Settings-001-reset
Message posted on 08 Jul 2023 08:10 PM
The one that does not erase recordings etc
Message posted on 08 Jul 2023 08:15 PM
Try rebooting your Q box again @polar68
Your Recordings should still be there. If you cannot make new recordings you may have an hard drive issue (however this is normally coupled with a hard drive error message)
Message posted on 08 Jul 2023 08:24 PM
Hi, we have just done the reboot and it didn't work. I tried to record a programme and it says 'service not available because of a problem with your hard disk drive'. Does that mean the box has had it?
Message posted on 08 Jul 2023 08:30 PM
Looks likely @polar68
I suspect your only option is to reset the hard drive in the hidden menu. You will lose all your recordings.
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Message posted on 08 Jul 2023 08:34 PM
Thank you for all your advice for now. We will do one more soft reset and start again tomorrow morning. Guess if this doesn't work, we have nothing to lose by doing full reset as can't access recordings anyway. Then it'll be a call to Sky as we do have one of the earliest boxes still
Message posted on 09 Jul 2023 09:21 AM
@oldfella still getting 'technical error' message when trying to download. We have ordered a replacement box now. Thank you for your help
