2
This discussion topic has been answered Discussion topic: Recordings are spasmodic, non existent or "there is a technical fault!!
This message was authored by: NannySan
Recording programmes has lost the plot lately.  Occcasionally they record and play, or say they have failed because of "Technical Fault with this Channel, please try later".    Sometimes they are scheduled to be recorded but do not record at all.  If I try and record during a programme because I am not able to finish watching ... there is that "technical fault" again.
Also I am not able to PAUSE anything any more.  Current programmes, or recorded ones.
It's all most unreliable and quite frankly doolally!  Can anyone help please?   I have tried resetting the router
This message was authored by: Laing1 Answer
Re: Recordings are spasmodic, non existent or "there is a technical fault!!
@NannySan Have you tried rebooting your main Q box ie
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for NannySan
Thank you.  That worked.  So simple.  I had reset but this time I switched all off at the mains and left it for a while and when I rebooted all was fine.  Many thanks 🙂
