Discussion topic: Recordings are freezing and skipping plus sometimes a Blue screen appears saying technical fault
This message was authored by: Jeff1234
Recordings freezing and skipping plus fast forward keeps on jumping back. Sometimes a blue screen appears saying technical fault with channel.
Recordings stating part recording software issue.
Sky very slow and unresponsive
Re: Recordings are freezing and skipping plus sometimes a Blue screen appears saying technical fault
@Jeff1234 Have you tried rebooting your main Q box ie
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
