Discussion topic: Recently moved house. Today got sky wifi set up but Sky Q won’t connect to it.
Message posted on 19 Mar 2024 08:29 PM
Sky tv has been set up for a couple of weeks and broadband setup today. However the sky Q can't connect via WPS nor can it find any wifi network.
Message posted on 19 Mar 2024 08:32 PM
Re: Recently moved house. Today got sky wifi set up but Sky Q won’t connect to it.
Hi @David230
Message posted on 19 Mar 2024 09:03 PM
Hi @oldfella, Wifi Router reset completed.
I am unable to perform a network reset on the sky Q as that option isn't available on the box. The only options available in the network section are connect to sky broadband (the option I am trying) connect to third party (tried but can't find any network) and connect used wire (can't use due to location)
I once managed to get though to the page to enter SSID (even though I have sky wifi) entered name and password but the screen just said connecting for 20 minutes.
unfortunately after trying all your recommended steps, the issue still persists.
Message posted on 19 Mar 2024 09:08 PM
I once managed to get though to the page to enter SSID (even though I have sky wifi) entered name and password but the screen just said connecting for 20 minutes.unfortunately after trying all your recommended steps, the issue still persists.
As I said @David230
You need to use WPS to connect to Sky WIfi router .
In your Q box if you select the option to Connect to Sky Broadband then the WPS light on the Q box should start flashing.
You then have 2 minutes to press the WPS on the Sky Router. Make sure that you press the router WPS button and not the router reset button.
Sky router WiFi button shown below
Message posted on 20 Mar 2024 08:08 PM
Sorry for not being clear. I have done this. In desperation I tried the other option too. None worked.
