Discussion topic: Recently moved away from sky broadband to fibrus. Broadband is now considerably better and stronger
Message posted on 26 Aug 2024 02:43 PM
Recently changed from sky to fibrus broadband and it is considerably better and stronger in the house.
However now the sky minis upstairs just won't talk to the sky q box downstairs even though the strength of wifi is 10 times better.
Done all the re boots etc but no joy. Can not get an engineer until 16/09 and been waiting a week now.
Mini boxes just won't connect to Q box.
Any help appreciated?
Message posted on 26 Aug 2024 02:45 PM - last edited: 26 Aug 2024 02:46 PM
Re: Recently moved away from sky broadband to fibrus. Broadband is now considerably better and stron
Hi @Worths1976
Reboot the minis as above.
. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or previously connected mini).
Message posted on 26 Aug 2024 02:47 PM
Yes tried all that but nothing.
Read things like turning off the wifi hot-spot on the minis but no sure.
Not even far from each other in my opinion.
Message posted on 26 Aug 2024 02:53 PM
You cannot turn off the Hotspots @Worths1976 as this turns off the WiFi which the Q boxes need for connection. If the nearest mini to the Q box will not connect then it looks like you need a Q WiFi Booster
Message posted on 26 Aug 2024 03:17 PM
@Worths1976 wrote:Recently changed from sky to fibrus broadband and it is considerably better and stronger in the house.
Q to Q connectivity uses its own mesh network and doesn't use your WiFi at all.
Indeed, your new router may be blocking the signal. Ensure your router is not using channels 36 to 48 on the 5 GHz band. Although, as noted, the distance may be too far without boosting.
