Discussion topic: Recent issues with Sky q box running slowly and on demand being glitchy
Message posted on 26 Mar 2025 02:38 PM
Hello.
Have a fairly old (around 7 yrs) sky q box. Over the last couple of weeks it seems to be running a lot more slowly, even moving between menus and opening apps.
In addition on demand services seem very glrichy and will either give me a download error or will appear to download but then give sound but a blank black screen (which doesn't even show a pause bar when paused)
Have tried clearing some memory, and in process of doing a software update, but wondering If anyone else has had similar issues, and roughly what the expected lifespan of a q box is, and if sky would potentially replace it if persistently playing up.
Don't think it's a connectivity issue as its a wired 1Gb connection which is stable on other devices.
Thanks in advance for any helpful insights.
Message posted on 26 Mar 2025 02:53 PM
Re: Recent issues with Sky q box running slowly and on demand being glitchy
Slight update, following pushing a software update my recordings now won't open at all, just have a loading circle and please wait.
Message posted on 26 Mar 2025 03:30 PM
Hi @Ashley871
Have you tried rebooting your Q box?
Message posted on 26 Mar 2025 04:39 PM
Millions of Q boxes have been distributed over nearly a decade, so yes.
Some v1 (2016) boxes will still be in use.
Yes, all Q hardware is on loan and replaced free of charge where necessary.
Message posted on 27 Mar 2025 04:25 PM
Thank you, yes have tried rebooting the box. Currently cannot access recordings, and trying to click anything in on demand menu g8ves a message saying due to a technical error this service is currently unavailable and kicks me out to the homescreen. Think I may need to call out an engineer and see about a new box.
But thank you for the suggestion
Message posted on 27 Mar 2025 04:31 PM
Hi @Ashley871
Failing all this
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
