Discussion topic: Rebooting my main Q box daily, even sometimes twice? What's the issue, is it time for an update box?
This message was authored by: EJ+Welch
Hi community, can someone tell me why my  Q box (main one) has to be rebooted at least once a day, sometimes twice.. Is this box dying and needs replacing?  Any advice appreciated. Sometimes it says no signal, then after reboot it's fine, but this shouldn't be happening daily or at least 3 or 4 times a week
Re: Rebooting my main Q box daily, even sometimes twice? What's the issue, is it time for an update
Hi @EJ+Welch
Try a Reset Settings in the Q box hidden menu. See if that improves the reliability.
This message was authored by: doc-ab
Kept having to reset box, missed / failed recordings eventually got a replacement box no problems since then, should have done it earlier
Avatar for EJ+Welch
Thank you oldfella:) Will try that, and if it presists will request a new replacement.
Avatar for EJ+Welch
Thank you for your reply Doc-ab, if oldfella's suggestion doesn't work I'll try for a new replacement:)
