Discussion topic: Re: Sky go wont connect to sky q box
This message was authored by: joyce111
Message posted on 13 Jan 2024 09:36 AM
I click the remote and nothing happens. Have done this for about 30 mins. Have turned TV of at wall still nothing. HELP
Find out more
Message posted on 13 Jan 2024 10:46 AM
Hi @joyce111
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
