Discussion topic: Re: My sky plus is getting no signal on some channels
This message was authored by: Satellite2
i also have been having terrible reception particularly on CNN on Sky Q. Thinking I might go back to cable
Moved from the Sky+ forum.
@Satellite2
No signal and no satellite signal issues are different .
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
You'd have to change your username then though
Probably a slight dish misalignment.
