Discussion topic: Re: My sky is saying no signal ,then it works for a minute and then it says no signal again ,then wo
This message was authored by: Mary281185
my sky is saying there is no signal
@Mary281185
No signal or no satellite signal?
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If you are seeing a message of “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s almost certainly a dish alignment issue so check the troubleshooting in this link
It’s worth remembering that a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
