1
This discussion topic has been answered Discussion topic: REMOTE NO LONGER CONTROLLING SONY SOUND BAR
This message was authored by: Simmolots
My sky q remote no longer controls sony soundbar. Also it no.longer turns lg tv off.
This message was authored by: nigea99 Answer
Re: REMOTE NO LONGER CONTROLLING SONY SOUND BAR
hi @Simmolots
May I suggest you try a reset of your remote:
Press & Hold the 7 & 9 until the remote's light (red LED above the SKY logo button) flashes 4 times
Then press 1 & 3 together to go through to re-pair with the box,  your TV & soundbar - make sure it has line of sight of the box as until it is paired it uses Infrared
https://www.sky.com/help/diagnostics/sky-q-remotes/setting-up-remote
hi @Simmolots
