Q no sat signal new t.v. Cabinet
Answered
Go to Answer
Managing Editor
Post 46 of 52
Re: Q no sat signal new t.v. Cabinet
@bob1234 wrote:
Things are not always what they seem, I have a 24" TV standing on top of a mini box, this you would think was the worse possible set up.
However the TV has a lightweight alloy stand which works as a heat sink and it actually drops the temperature of the mini box 2 degrees compared to free standing.
Fair comment @bob1234 but as the Sky  Q Mini Boxes don't have an hardrive and 12 tuners it's like saying 'the lights are on but nobody's at home'
Editor
Post 47 of 52
When I tested the thermal gradient across the top surface of my mini, it very soon became clear that the plastic case, even with its thermally conductive fillers, still exhibited quite a high thermal gradient across its surface area.
I leave others to draw their own conclusions as to how 'breathable' or as I prefer to describe it 'thermally conductive' the plastic case actually is.
(With just an Ethernet connection, all Wi-Fi turned OFF)
Godfrey.
Executive Producer
Post 48 of 52
Godfrey.
Yes very similar to the measurements I got with it free standing.
Editor
Post 49 of 52
My parts order was declined as min £10 order required. Need to re consider this tonight.
Editor
Post 50 of 52
@Donfor wrote:
Thanks @Godfrey I did see the back to back f connector.
Your advise is very much appreciated and cost effective I must say appreciated.
Total £4.51 ordered
2PFADAPTPush fit F connector adaptor
1OPTWSTWWOption Add an additional meter of white twin Webro WF100 cable to my made up length
2FBTOBACOne F Connector back to back coupler
You needed to select and order the initial terminated length of made up cable...................
Thus, the correct code for 1 m length of WF100 Twin in White is 1TWINBCW
Godfrey.
Editor
Post 51 of 52
i could phone and make the order up to a tenner or select 6 pounds delivery if I continue to purchase online
Editor
Post 52 of 52
When you correct the order for your 1 m length of Twin White WF100 the order value will meet the minimum order value.
Godfrey.
Recommended Threads
26-04-2018 02:48 AM
04-06-2018 08:31 PM
21-04-2018 08:43 AM
22-03-2018 07:20 PM
30-03-2018 07:06 PM
