Q no sat signal new t.v. Cabinet
Answered
Go to Answer
Editor
Post 31 of 52
Re: Q no sat signal new t.v. Cabinet
@Mark-Br wrote:
Can we please get back to the topic of cooking equipment?
Totally agree Mr Ramsey. Cooking equipment it will be from now on. What’s the problem? Saucepan handle loose?
Executive Producer
Post 32 of 52
I can recommend the Tefal "cook for me"
Editor
Post 33 of 52
@Donfor wrote:
I have no concerns at this time other than the rediculously short dish input 1 cable.
If you searched for a Push-ON / Pull-OFF quick release F connector adaptor, which is what quite a few of us use on our test meter cables, you could easily add 2.3 cm to the effective length of the coaxial cable that you suggest is presently a bit too short for comfort.
Godfrey.
Editor
Post 34 of 52
Thanks I've a few mins to search for the push/pull f connector you kindly mentioned and the brackets to consider.
Sat sig seems stable since yesterday.
Editor
Post 35 of 52
I'm not certain about the F connector.
Is it possible to purchase a short peice of sat cable as I could as suggested by a kind forum poster-extend my dish input 1 cable maybe by adding an extra peice of cable-though I don;t need 10 meters that I've just seen on another site.
The F connector sounds simple to connect where the cable is already attached to original cable-which it is unless I had to move q box at all, i.e. not secure at all,
Editor
Post 36 of 52
@Godfrey Is there a link for your recommended quick releases F connector and a short piece of sat cable.
Via amazon I've 26.98 total router bracket+Apple 4k t.v. Bracket.
I presume I could continue to sit both devices on top of Q  with these brackets.
https://www.amazon.co.uk/Wall-Mount-Apple-TV-4K-Black/dp/B07BPX8KL8
https://www.amazon.co.uk/Q-View-Router-Bracket-Mount-HQB-SKYQHB-Black/dp/B07DLFXGN8
Editor
Post 37 of 52
Which type of sat cable shall I purchase and if I extend input 1 cable do I javelin to purchase shotgun cable and extend inout1+2 cables rather than one or the other.
Asking ahead of ordering all required bits from Amazon.
This acceptable as input 1 cable extension
 https://www.amazon.co.uk/Satellite-Cable-Premium-Coaxial-Connector-Black/dp/B01N9SBMCG
Editor
Post 38 of 52
http://www.satellitesuperstore.com/satellitecable.htm#fpush
http://www.satellitesuperstore.com/satellitecable.htm#twincablemadeup
I must admit that I am also concerned that you are continuing to attempt to justify placing your Sky Q receiver in a cabinet that does not have an open back, let alone placing other devices on top of it, but that is just my personal opinion as a retired specialist engineer with over 31 years experience in the design, operation and maintenance of professional broadcast equipment.
Godfrey.
Editor
Post 39 of 52
@Godfrey Last question tonight please
Whch connector do I use for the joints of additional cable is to more F connectors
Editor
Post 40 of 52
If you scroll up from the link to the Push-ON / Pull-OFF adaptor you should see a Back to Back F coupler.
Godfrey.
Editor
Post 41 of 52
Thanks @Godfrey I did see the back to back f connector.
Your advise is very much appreciated and cost effective I must say appreciated.
Total £4.51 ordered
2PFADAPTPush fit F connector adaptor
1OPTWSTWWOption Add an additional meter of white twin Webro WF100 cable to my made up length
2FBTOBACOne F Connector back to back coupler
Editor
Post 42 of 52
Thanks all whom replied. Efforts are appreciated.
I shall complete extension and f connector tweak before proceeding with brackets ordering.
It's been fun at least getting to use ipad 10.5 camera for a while.
Editor
Post 43 of 52
This is what I believe in-
It’s completely normal for your Sky Q boxes to be warm as they’re built with “breathable plastic” that naturally releases heat through the top of the boxes.
Managing Editor
Post 44 of 52
@Donfor What others are concerned about me included is that the Sky Q box does get warm and yours is located in a unit with no way for the heat to escape.
You've ascertained that naturally releases heat through the top of the boxes.
The Sky Q router releases heat from the top and the bottom adding to more heat build up within the confined space.
You also say 'breathable plastic' but if you are going to put things  on top then it's unable to breathe effectively that's why I suggested the brackets.
I'm waiting for a bracket for my 4K🔥TV It's not placed on my Sky Q box it dangles below the tv and looks out of place.
Executive Producer
Post 45 of 52
Things are not always what they seem, I have a 24" TV standing on top of a mini box, this you would think was the worse possible set up.
However the TV has a lightweight alloy stand which works as a heat sink and it actually drops the temperature of the mini box 2 degrees compared to free standing.
Recommended Threads
26-04-2018 02:48 AM
04-06-2018 08:31 PM
21-04-2018 08:43 AM
22-03-2018 07:20 PM
30-03-2018 07:06 PM
