Discussion topic: Q mini box wont reconnect after powering off
Message posted on 09 Sep 2024 09:59 AM
i've got a mini box connected to my main box (1TB) by ethernet cable and i've disabled the wifi 2.4 and 5ghz in the hidden menu to avoid any conflicts over connectivity.
Every thing works perfectly well except if i switch off the mini box at the wall, after restarting the mini box it will not reconnect automatically to my main box - i give it plenty of time but if refuses to reconnect automatically.... the only way i can get the mini box to reconnect without going through the whole setup procedure again is to reboot my main box then within a couple of minutes the mini box will reconnect....
the software on both boxes is up to date, all i can think is that it's an hardware issue with my main box and the fact that it's about 6 years old ....
any thoughts on the above would be most welcome THX.
Message posted on 09 Sep 2024 10:55 AM
Re: Q mini box wont reconnect after powering off
Hi @brid+dave .
When you connect a mini by Ethernet it's important to carry out a Network reset as follows.
Network reset with the Ethernet connected.
Network Reset found in mini box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Do not carry out any WPS and just wait for the box to connect. It may take a couple of minutes. If it does not connect there is an issue with the Ethernet connection.
As soon as it connects go immediately into the mini box hidden menu and turn off WiFi.
Go to Network to turn off both bands of WiFi. Confirm before exit.
Message posted on 11 Sep 2024 10:04 AM
@oldfella carried out the instructions above and it still will not reconnect after turning the power off at the mini box, it will only reconnect if i power down my main box then switch that back on .....
ethernet connection works perfectly well once it is reconnected....
i can't think beyond a problem with the main box and how it shares its connectivity over ethernet ..... like i say it must be circa 6 years old and an early box, the software is up to date but you can't do anything about the hardware
Message posted on 11 Sep 2024 10:11 AM
Hi @brid+dave
Fail to understand why you are turning the mini box power off at the wall.
Boxes are intended to be left in Standby when not in use.
Message posted on 11 Sep 2024 10:28 AM
in the long term it will be left switched on, i'm just trying to get it set up so i don't have to go through the rebooting of the main box (interupting viewing on the main box) .....
in the area that i live we suffer frequent power cuts, all be it only seconds it's enough to cause this issue.
