Discussion topic: Q mini box will not show BBC etc will show sky channels
This message was authored by: Mark423956
I have a QBox and 2 mini boxes
The mini box will not link to non sky channels eg BBC
any ideas ?
asks to check my subscription to view this channel ?
account is in order and the other mini is accessing ok ??
Re: Q mini box will not show BBC etc will show sky channels
@Mark423956
Try a reboot of your router then reboot the main Sky Q box, then once that’s back up and running do the same with both mini boxes if necessary-
~ press the 🏠 button
Avatar for Mark423956
Thanks Daniel
tried the reboots - the issue remains
to confirm - I have Q prime & 2 mini boxes
1 mini box works perfect
the other only pulls through sky channels not the terrestrial channels bbc /  itv / Channels 4 & 5 etc.
message on 101 is programmes not accessible- check subscription- called Sky - all good - they referred me to tech / here !!
I'm struggling as I assumed the minis take a feed direct from the mother box - so why would it not feed everything & the other mini is fine !!
Frustrating
