Discussion topic: Q mini box is connected and working for apps but I can't get any TV channels
Message posted on 17 Feb 2024 01:13 PM
My Sy Q mini-box is connected to the internet and the main Sky Q box. I can get apps but all the channels say I'm not registered to view them. I've tried all the suggested reboots without success
Message posted on 17 Feb 2024 01:14 PM
Re: Q mini box is connected and working for apps but I can't get any TV channels
Do you have a multiroom subscription?
Message posted on 17 Feb 2024 01:19 PM
Yes. It was working yesterday
Message posted on 17 Feb 2024 01:31 PM
Have you rebooted both boxes?
Message posted on 17 Feb 2024 01:47 PM
Yes
Message posted on 17 Feb 2024 02:24 PM
@terry444 You could try refreshing your viewing card by pressing home > settings > system info > viewing card number > setup > viewing card setup press select to trigger a callback don't worry nothing to do with your phone its only Sky's terminology this will be done over the internet
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 19 Feb 2024 11:27 AM
Hi thanks for the advice. I tried everything that you guys recommended and also later on spent 55 minutes on the phone with an expert from Sky. We even tried to update the software on the Sky Q box and mini-box but the problem remained. We've now booked a visit from a Sky engineer. I suspect it may be a problem with the software on the Sky mini-box as that update failed (the main Sky Q box was updated successfully) Thanks again for trying to help
