Discussion topic: Q box won’t be suitable for k TV can I exchange
This message was authored by: Diane164
Will Sky let me have a Q box upgrade as one I have is not HDK compatible
Re: Q box won’t be suitable for k TV can I exchange
@Diane164
I'd assume you mean UHD.
A UHD television set will upscale HD from a Sky box to UHD for display.
They'd typically charge for a change of box.
@TimmyBGood wrote:
@Diane164
@Diane164  note SKY also usually charge for an upgrade from a UHD non HDR box to an HDR capable one
Hi @Diane164   You have left us all guessing (HDK). Do you mean UHD or HDR?
UHD (4K) I expect
That was the really early 1TB Q boxes wasn't it? I think they might be talked into a free box uograde if you subscribe to the UHD addon and ask at the same time.
