Discussion topic: Q box voices don’t match up
Message posted on 27 Apr 2025 07:07 PM
When the person on the Tv programme is talking it doesn't match up on the screen. Got to turn off q box to reset. A few days later it happeneds again.
Message posted on 27 Apr 2025 09:48 PM
Re: Q box voices don’t match up
Hi @Norwichjohn
Try a Reset Settings in the Q box hidden menu. See if that helps.
