Discussion topic: Q box red light n permanently after reset
Message posted on 03 Sep 2024 05:50 PM
The red *recording" light remains on even after reset and when I switch on, there are lines across TV screen.
Message posted on 03 Sep 2024 05:58 PM
Re: Q box red light n permanently after reset
Message posted on 03 Sep 2024 09:08 PM
Using this instruction: Press and hold 7 & 9 together on the remote until it's led flashes four times. Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Message posted on 03 Sep 2024 09:17 PM
That's to reset the remote @Scorp3
Were you trying to reset the Q box?
Message posted on 04 Sep 2024 05:45 PM
Yes. It's already been switched off then on again and the issue is persisting. I feel I may need a new Q box
Message posted on 04 Sep 2024 06:23 PM
Hi @Scorp3
Switching the Q box on and off is not a reset.
It's just a reboot.
Resetting the remote also does not reset the Q box.
If you want to reset the Q box you need to do the following.
Reset Settings in the Q box hidden menu.
