Discussion topic: Q box not connecting to router
Message posted on 12 Feb 2025 06:58 PM
Message posted on 12 Feb 2025 07:02 PM
Re: Q box not connecting to router
@Tone144 wrote:
Was connected but lst connection and won't re connect
Hi @Tone144
