		Discussion topic: Q box not connecting to router.
	This message was authored by: BroK1234
		Message posted on 15 Dec 2023 07:08 PM
Qbox won't connect to the router. I have tried WPS, gone through another provider and manually putting in the password. It recognises the wifi but won't connect
	This message was authored by: BaileyGB
		Message posted on 16 Dec 2023 08:53 AM
							Re: Q box not connecting to router.
@BroK1234 wrote:Qbox won't connect to the router. I have tried WPS, gone through another provider and manually putting in the password. It recognises the wifi but won't connect
Have you tried hardwiring it, just to see if it works. If it does, you'll know there is possibly a WiFi issue.
