16 Oct 2023 10:36 AM
Hi q box upstairs stuck on one channel
when rebooting says lost internet connection
but can't go into settings as box stuck on home
16 Oct 2023 10:48 AM
Posted by a Superuser, not a Sky employee. Find out moreWould suggest repowering your main Sky Q box, leaving off power for a few minutes.
Then, repowwer your Sky Q mini upstairs.
Would not harm in also restarting your broadband router.
@Joeo007 wrote:
Sky Qbox upstairs stuck on home
reboot and says not connected to internet
but can't get into settings to check connection as stuck on home
Hi @Joeo007
Check that the Home button is not stuck.
If it is OK
Try completly resetting your Bluetooth remote.
