Discussion topic: Q box in the bedroom not collecting
This message was authored by: Philly2
U have turned the main rounter off downstairs to reboot my sky q box in the bedroom. I have repeated this several times and it won't connect to the q box . It is saying error MR102. This problem is occurring every night around this time. Very frustrating 😕
Re: Q box in the bedroom not collecting
@Philly2 Have you tried rebooting your main Q box ie
then
rebooting the mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Hi @Philly2
try a Network Reset on the mini.
