Discussion topic: Q 2tb box says no internet connection., but apps work
This message was authored by: Rugdoc
This is happening often.
I have cleared recordings to less than 50%,  and when I do a network reset it connects (eventually) but 24 hours later,  does the same.
WiFi does appear to work fine. So is this a problem with the Q box?
Re: Q 2tb box says no internet connection., but apps work
If apps work, does anything not work?
Hi @Rugdoc Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on?.
Avatar for Rugdoc
Yes I tried that,  it used to happen once a year,  now it's every 24 hours of so,  is something failing possibly?
