Discussion topic: Problems watching recordings on sky signature
This message was authored by: Ninnny
Hi.
I recently downgraded my package to Sky signature only but thought it included Sky Max, Witness, Atlantic and boxsets.  I've just gone in to watch some recordings and am getting the message I need to upgrade to watch this channel. The S for standard definition is highlighted so am I being stupid and missing something or should I be able to watch?  I tried things from past downloaded boxsets and my own recordings.
Thanks for any help.
Re: Problems watching recordings on sky signature
@Ninnny wrote:
Hi.
Hi @Ninnny
The S  on the Recording tiles is for Subtitles not Standard definition.
First check that you are not trying to Download or view HD or UHD content without the Q HD or UHD Subscription pack.
The Sky Q Sports pack and BT Sport if you subscribe through Sky are in HD as Standard.
Sky Cinema if you subscribe is also in HD.
Sky Signature includes BoxSets and Entertainment channels only in SD as standard.
Only free to air channels such as BBC, ITV etc are in HD. The Q HD pack is required for all other Sky Signature HD content, including Catch Up in HD, On Demand in HD and BoxSets in HD
If you do not have the Optional HD pack you need to change the Download to SD in All Formats (as HD is the default setting).
So that you do not need to do this every time it’s best to change your Download preference to SD in Home - Settings - Setup - Preferences.
This needs to be done on the main Q box.
Then if you want to download any HD content from free to air channels (BBCHD ,ITVHD etc) you can select HD in the All formats tab of the content . This will change the format for that particular download only but still leave your format to SD in preferences.
Avatar for Ninnny
Thank you @oldfella .
I'm busily deleting and re downloading content but so far you advice seems to have worked.
Thanks for saving my sanity
