Discussion topic: Problems connecting additional box to main Sky Q hub….since alterations putting in Fibre
This message was authored by: Tinamac1983
Message posted on 23 Jul 2025 05:49 PM
Need an Engineer to visit to fix problem with connection. Have tried everything it tells me to do but it will not connect. It's probably something simple that the engineer will see but being a pensioner I'm finding it impossible.
Find out more
Message posted on 24 Jul 2025 08:16 AM
Re: Problems connecting additional box to main Sky Q hub….since alterations putting in Fibre
Have you now got a white Sky router?
The connection between the mini and Q has to be direct if you do.
