This discussion topic has been answered Discussion topic: Problem with satellite signal on BBC and ITV
Message posted on 28 Aug 2024 12:05 PM
Can anyone help please
Message posted on 28 Aug 2024 12:46 PM
@TJ40
If a message displays “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
@TJ40
Message posted on 30 Aug 2024 05:19 AM
Re: Problem with satellite signal on BBC and ITV
Thank you
