Discussion topic: Poor sound quality on LFC v Bournemouth
This message was authored by: Al2447
Anyone else got poor sound quality on commentary. Really quiet compared to crowd. Sky - turn crowd down and commentary up.
This message was authored by: DAA1
Re: Poor sound quality on LFC v Bournemouth
Our signal is breaking up. Can't watch it properly
Hi @Al2447   Main Event UHD, the commentary started off very quiet, okay now.
@Al2447
Turned it over after reading these posts. Okay here on Sky Q on HD and UHD.
This message was authored by: Mike631
Tried rebooting but this did not solve the issue. Picture and sound breaking up on all channels
@Mike631
That sounds more like a dish issue. Any error message on screen?
It's on wifi but connection is ok and no messages just pixelated screen
This message was authored by: SirDen
Re: poor sound quality sky football
I too am finding the mix of sound levels between crowd and the commentary team to be much too biased towards the crowd levels. This has to be something the editors in the outside broadcast control vans can adjust.
I'm watching the first game of the new 2025/26 season, and during half time the presenters and pundit’s levels were perfect, but as soon as it went back to the match commentary the spoken volume noticeably dropped and we’re back to trying to hear the spoken word over the cheering and singing.
They did it perfectly during covid, when crowd noise was ‘added’ to the background of the commentary. I'm all for being able to join in and revel in the reactions of the crowd to what's going on on the pitch, but do we really need to have it so loud it's making the commentators inaudible? Come on Sky, you're the best sports broadcaster out there, but your football coverage is being spoilt for many viewers, and it can't be too much of a problem to fix.
This message was authored by: MSPoling
Exactly the same.
Pixelated picture and intermittent sound.
Avatar for Al2447
It's better now, but not great. Still unbalanced with crowd.
It was a live game wasn't it on a standard channel?
This message was authored by: Rufus1234
The sound quality totally spoils the viewing. The sound quality on the cricket channel is perfect, crystal clear. Sky should acknowledge there is a problem and then fix it.
Have you reported it?
viewerR@sky.uk
Thanks. Problem reported. Hopefully it will be addressed and problem resolved.
The sound quality for tonight's game was muched improved. Someone must have tweaked the right buttons. Just hope it continues.
