Discussion topic: Poor signal channel 4
This message was authored by: Fernwood2002
Channel 4 is a bad signal as is a couple of other channels
Re: Poor signal channel 4
@Fernwood2002
Any on-screen error message?
If a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. After that look at the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish (it’s not something that will necessarily be visible to the naked eye). If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
▪️I AM NOT A SKY EMPLOYEE (undercover or otherwise) ▪️
