Discussion topic: Poor satellite signal in rain can i stream sky
This message was authored by TipTop16 This message was authored by: TipTop16
Hi we live near a wood and hill and despite a strong signal get poor reception when rain is in the area
This message was authored by martswain This message was authored by: martswain
Re: Poor satellite signal in rain can i stream sky
Yes, via Sky Go on a computer or smartphone.
TipTop16
sorry i mean on the tv
This message was authored by Exiled-in-HH This message was authored by: Exiled-in-HH
Sky GO is available on Apple TV 4K boxes which can be attached to your TV.
hi @TipTop16
You really shouldn't loose signal unless there are thunderclouds or similar
Maybe worth asking SKy to check the dish alignment - unless the trees are specifically in the way of the dish & the Satellites (approx 22000 miles above th earth) in which case  it will depend on what alternatives are availble.
This message was authored by Jason+Golding This message was authored by: Jason+Golding
Sky stream isn't affected by the rain at all. Satellite tv can be affected by the rain, if it is extremely heavy. Normal rainfall shouldn't affect your picture via satellite - I would suggest your dish is misaligned
Sky Stream x 2
LG C2 OLED 55inch
Sonos Playbar
Virgin 1 Gig
Virgin Stream Box
Xbox X
Apple TV 4K
Amazon 4K Firestick Roku 4K Google Chromecast
This message was authored by stereohaven This message was authored by: stereohaven
Whilst you get your dish alignment sorted @TipTop16, worth noting that using the "big screen" version of Sky Go only works on the likes of Apple TV or game consoles if you have a multi screen subscription. Sky help says it works on a console if you have "Sky Go Extra", but I'm not convinced that is still correct.
If you have a laptop or PC you can plug it into yourTV and that will work, as long as Sky Go believes the TV is the only monitor.
LG B6 OLED 55” | LG UP75 LCD 43” | Sky Q | Sky Q Mini | Apple TV 4K | SONOS Beam 2 | Sky Mobile | FTTC BT Halo 3+
Sky wholehome is required to use Sky Go on games consoles or Apple TV box. Also worth noting that the BBC channels are not available
Sky Stream x 2
LG C2 OLED 55inch
Sonos Playbar
Virgin 1 Gig
Virgin Stream Box
Xbox X
Apple TV 4K
It is slightly different for those with SKY Q - BBC channels are available when SKY Go is connected to the SKy Q box (which neds the Q equivalent - Multscreen to connect)
@TipTop16 @Maybe sky stream is a good option then
Sky Stream x 2
LG C2 OLED 55inch
Sonos Playbar
Virgin 1 Gig
Virgin Stream Box
Xbox X
Apple TV 4K
This message was authored by Chodley This message was authored by: Chodley
@nigea99 wrote:
hi @TipTop16
22000 miles above the equator though, which is not at that high an angle from the UK, especially in Scotland.
